Fan motor only works on high?
Old Aug 8, 2010 | 07:46 PM
Care-A-Van's Avatar
Care-A-Van
Default Fan motor only works on high?
I have a 2001 Ram Van 3500 and the blower fan motor only works on high? Anyone know what might be wrong or what to check? Thanks
Old Aug 8, 2010 | 09:08 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Blower motor resistor pack under the hood on the HVAC box. It will be on the side of the box that faces the engine. Either it is unplugged or the pack is broken.
Old Aug 8, 2010 | 09:33 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Also, it has a flat 4-wire connector going to it.
Old Aug 12, 2010 | 11:31 AM
RossOlson's Avatar
RossOlson
This is seems to be an issue with Jeeps of similar years. A couple things seem to happen. Your resistor goes out, when this happens your fan only works on high. Your fan switch goes out, this happens when certain fan setting won't work but other will, or everything goes out and this is often the mode switch.
What seem to cause it as the fan ages it draws more amps and starts melting switches and wires. Relays and fuses don't catch it.
I just got down replacing a wiring harness, a couple switches and the resistor in my jeep, the set up seems to be about the same in the dodges.
I also have a dodge ram van and want to change out the blower before I have problems.
In the jeep the fan is easy to get to, can anybody tell me how to get to it in the ram van?
Old Aug 12, 2010 | 12:27 PM
alloro's Avatar
alloro
From under the hood, and it's rather easy.
Remove a few screws, pull out the drain tube, unplug the connector, and out she comes.
Old Aug 12, 2010 | 01:54 PM
RossOlson's Avatar
RossOlson
I briefly looked in there the other day and did not see the fan. Does anything have to come off to get to it? I am assuming you get it from the top.
Old Aug 12, 2010 | 10:46 PM
Care-A-Van's Avatar
Care-A-Van
I put in a new fan motor resistor and I have all speeds now. Thanks for the tips.
Old Aug 13, 2010 | 10:45 AM
alloro's Avatar
alloro
It's mounted into the side of that big black box on the passenger side of the underhood area. It comes out from the top.
