turn signals & radio looses power on & off
Old Dec 6, 2010 | 12:49 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
That is it.
Old Dec 6, 2010 | 01:04 PM
Care-A-Van's Avatar
Care-A-Van
Thanks
Old Dec 6, 2010 | 04:22 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Originally Posted by Care-A-Van
Here is a picture of the ignition switch below the ignition lock cylinder. Is this what I need?
Yes, that's the ignition switch.
Old Dec 16, 2010 | 06:11 PM
2002 Dodge 1500 Conversion Van's Avatar
I'm having the same problem. I can't locate the part anywhere. Any suggestions? I also have the key on fob with nothing else.
Old Dec 16, 2010 | 09:05 PM
Care-A-Van's Avatar
Care-A-Van
I found the part at Napa
Old Dec 18, 2010 | 08:13 PM
stev's Avatar
stev
If there isn't a NAPA near you, order it on-line from them.
Old Dec 19, 2010 | 04:35 PM
02 Ram Van 1500's Avatar
02 Ram Van 1500
Default Found new ign switch at PepBoys.$26, still have problem accessing it.
I just picked my ign switch for my van at PepBoys. It was $26.00 and is made by Borg Warner.
I tried to loosen the 2 screws on the bottom of the cover and had to buy a very long handle T-20 torx screwdriver. One of the screw is very deep and very tight. I removed the shallower depth screw with no problem. The deeper one was very tight and sounded like it cracked something when I was able to turn it. It didn't come out and I couldn't remove the covers.
I don't know if I have to pry anything loose or remove the tilt wheel ****. Any ideas?
I disconnected the battery while I was doing this just in case it would be an issue.
Old Dec 25, 2010 | 06:14 PM
02 Ram Van 1500
I replaced my ignition switch this past week and everything works beautifully. Even the brightness of the headlamps seem a little brighter that before. Thanks for all of your help. It was a little difficult with the tilt steering wheel not working. I couldn't tilt the wheel upwards.
I thought I could do an easy repair of the tilt problem. I couldn't see what was not working properly. I will have to make a new post.
Old Dec 27, 2010 | 02:34 PM
moparman54's Avatar
moparman54
I've got the same thing on my 2002 ram van 1500. When I jiggle the keys it goes away.....So, it's the switch, not the lock cylinder, right? Electrical parts can be hard to return, so I want to make sure it's not the cylinder. Mine is ready to go.
Will I have to take off the wheel?
Old Dec 29, 2010 | 09:28 AM
moparman54's Avatar
moparman54
Well, I ordered the switch and it should be in today. Napa $31 I've got the two screws holding the cover off, and just like yours, the deep screw was very tight. How do I get the cover off? Do I have to pry the top cover off of the bottom? I'm afraid of breaking it. 2002 Ram Van 1500 (conversion)
