WHooooosh is the noise I hear
Old Nov 22, 2010 | 10:05 PM
TheDirtySanchez's Avatar
TheDirtySanchez
Question WHooooosh is the noise I hear
My van 92 dodge ram b250 v6 3.9 auto started making this loud whooosh noise every time I accelrate ...what gives?
Let me add more, I can hear it out the drivers side window from under the van ,I don't see any holes in the pipe.
Old Nov 23, 2010 | 01:07 AM
sparkzz's Avatar
sparkzz
My first absolutely uneducated guess would be the fan clutch.
Old Nov 23, 2010 | 08:22 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Originally Posted by TheDirtySanchez
My van 92 dodge ram b250 v6 3.9 auto started making this loud whooosh noise every time I accelerate...what gives?
That's the afterburners kicking in.
Old Nov 23, 2010 | 01:10 PM
TheDirtySanchez
Nope not the fan clutch ...all thats new with the new water pump i put in this past summer ...this noise just started it seams after i put in the new computer
Old Nov 23, 2010 | 09:41 PM
familytruxter's Avatar
familytruxter
fan clutch is supposed to make a whooooooosh sound...if it doesn't you could overheat
Old Nov 23, 2010 | 09:43 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Wondering if you are hearing something from the transmission. Didn't you use to power brake this transmission and have the thrust bearing try to come out of the tranny or was that someone else? If so I don't remember if you had the transmission rebuilt or if you just had a new thrust bearing installed.
I would look for a crimped or restricted transmission fluid line. Also check the fluid level for it may be low.
Old Nov 23, 2010 | 09:48 PM
Mobile Auto Repair
If it is the fan clutch then after you have gotten up to speed and with in a minute or less it should kick out and not make the whoosh/roar sound. And you will hear it whether the window is open or not.
Old Nov 23, 2010 | 11:00 PM
TheDirtySanchez
IDK what it was ..the Van had a loss of power like it wasn't running on all cylinders, but I took it out on the Hwy 2day and after about 2 minutes the noise just stopped and the power came back ...weird.
Old Nov 24, 2010 | 12:14 AM
landyacht318's Avatar
landyacht318
It was either a rodent stuck in the serpentine belt, or the sounds of all the jobs being outsourced to Asia and Mexico just as H Ross Perot said way back when.
Really, I'd check the Air cleaner, make sure it an it's cold air feed tube are mating nicely.
Old Nov 25, 2010 | 02:29 PM
stev's Avatar
stev
A whoooosh sound?
TSB 07-01-92
Viscous Fan Drive Noise
http://dodgeram.info/tsb/1992/07-01-92.htm
Date: May 18, 1992
Models:
1992 (AD) Ram Truck with 3.9L V6, 5.2L V8
V6, V8 engines in:
1992 (AB) Ram Van/Wagon
1992 (AD) Ram Pickup/Ram Cab & Chassis/Ramcharger Power Ram Cab & Chassis
1992 (AN) Dakota/Dakota Sport/Dakota Cab & Chassis
Symptom/Condition:
Some vehicles may exhibit a cold start fan "roar" noise for the first 1-2 minutes of operation/or the transmission may seem to be slipping. Customers may complain that the transmission is staying in low gear (delayed upshift). Vehicles exhibiting this condition should have this bulletin performed.
Parts Required:
1 Viscous Fan Drive
AB Body 3.9/5.2L Standard Cooling 52027847
AB Body 3.9L Max Cooling (Sales Code NMC)
AB Body 5.2L Max Cooling (Sales Code NMC) 52027848
AD, AN Bodies 3.9L All Cooling Packages 52027858
AD, AN Bodies 5.2L Standard Cooling 52027860
AD, AN Bodies 5.2L Max Cooling (Sales Code NMC) 52027862
Repair Procedure:
This repair involves replacement of the viscous fan drive with a revised one.
1. Remove the fan drive as outlined in the appropriate service manual.
2. Replace the appropriate fan drive with one called out in PARTS REQUIRED.
Notes:
POLICY: Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Operation No. 07-20-15-90 AB . . . . . . . . . . . . . . 0.8 Hrs.
AD, AN . . . . . . . . . . 0.5 Hrs.
FAILURE CODE: 68 - Noisy
