Miss at idle and rough idle, ideas?
Old 02-26-2011, 06:58 PM
IcantDo55's Avatar
IcantDo55
IcantDo55 is offline
Pulled codes
P0300
P0304
P0303
I'll try cleaners and report back.
Nobody thinks it could be a cam or crank position sensor?
  #22
Old 02-26-2011, 08:29 PM
alloro's Avatar
alloro
alloro is offline
Van & CUV Section Moderator
Dodge Forum Moderator
Those sensors will affect all cylinders, not just two.
  #23
Old 02-27-2011, 10:02 PM
IcantDo55's Avatar
IcantDo55
So what affects only cyc 3 and 4?
  #24
Old 02-27-2011, 10:20 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Mobile Auto Repair is offline
Originally Posted by Mobile Auto Repair
Also
vacuum leak
Intake Plenum pan leak
^Did you check the Intake plenum pan for leakage?
  #25
Old 06-29-2011, 12:08 PM
IcantDo55's Avatar
IcantDo55
Ok finally got around to fixing the plenum issue. Water pump bearing let go so I pulled it and replaced the WP, Radiator, fan clutch, intake plenum gasket and lower intake gaskets. Started it up and it cleared codes and it seemed a little smoother went for a drive and got P0303 again!
So just to review and save you from 3 pages:
Originally got P0300 and P0303
removed and cleaned the IAC
replaced oil, oil filter
air filter
wires, plugs, cap, rotor
flushed cooling system
cleaned the PCV
replaced ignition coil
Checked compression on #3, #5 for comparison, both are around 120psi.
moved #3 injector to #5 spot did not change anything
Clean all grounds
Tried fuel injection cleaners
So any other ideas beside a gallon of gas and a match?
  #26
Old 06-29-2011, 12:15 PM
bwdakrt's Avatar
bwdakrt
bwdakrt is offline
What type plugs did you use and what how did you gap them? .040??
  #27
Old 06-29-2011, 12:16 PM
IcantDo55's Avatar
IcantDo55
Autolite coppers .035
  #28
Old 06-29-2011, 12:24 PM
bwdakrt's Avatar
bwdakrt
bwdakrt is offline
The Autolites would not be my first choice in plugs. I've tried those before and now running 4291 NGK and like them a lot better. The .035 is too close of a gap and may be your problem. A stock 3.9 engine should be no less than .040 gap.
  #29
Old 06-29-2011, 12:28 PM
IcantDo55's Avatar
IcantDo55
I'm reaching here so I'll try anything. NGK here I come.
PS: I do run Autolite cop in every other car I own (including 700whp SC stang) and there great, but you are right some motors are finicky.
Thanks
  #30
Old 06-29-2011, 12:34 PM
bwdakrt's Avatar
bwdakrt
bwdakrt is offline
I'm not saying the Autolites are not good plugs because some people swear by them in these Magnum engines. Just voicing my personal choice. The choice to change them is your decision but the .035 gap is what I believe to be the problem and should be increased to .040.
Quick Reply: Miss at idle and rough idle, ideas?
