I can't figure out why I am misfiring help please !
Old Apr 19, 2011 | 03:47 PM
Samd's Avatar
Samd
Default I can't figure out why I am misfiring help please !
I have a 1999 v 6 b1500. I'm pulling a code for a random misfire and also misfiring cylinders 1 3 and 5.my fuel pressure is fine when is running I'm going to test it tomorrow first thing in the morning. it has new wires and plugs n a distributor cap. I am at a loss .... please anyone help
Old Apr 19, 2011 | 05:00 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
I've had this same issue for 3-years now. The only things I have not yet done are replace the head or the distributor. I'm leaning more towards the head since the problem is only on the one side.
I've replace the ECM, pick-up coil, ignition coil, crank sensor, cap, rotor, wires, plugs, injectors, intake manifold gaskets, and removed and cleaned out the fuel rail. Nothing has made a difference. So if you happen to get lucky and solve the issue I'd sure like to hear how you did it.
Old Apr 20, 2011 | 12:16 PM
Samd's Avatar
Samd
O Damn ill try my beat but I have no desire to change my head! Damn.. well ill keep trying. Will it hurt my engine to keep running it like this? Also its really hard to start in the morning just keeps turning over u think thats the misfire? Or something else
Old Apr 20, 2011 | 12:41 PM
alloro's Avatar
alloro
That's a sign of a bad fuel pump.
Old Apr 21, 2011 | 12:14 PM
Samd's Avatar
Samd
That's what I thought so I turned the van on the accessorie and unhooked the fuel line and it was pumping good so I thought it was fine? Am I right
Old Apr 22, 2011 | 12:46 AM
Mobile Auto Repair's Avatar
Mobile Auto Repair
It may have the flow but may not have the pressure. These engines want 39-41psi to run correctly. Also hard starting in the morning may mean that the anti flow back valve is not holding pressure in the fuel line overnight.
Old Apr 22, 2011 | 12:44 PM
alloro's Avatar
alloro
Which is built into the fuel pump assembly.
Old Apr 22, 2011 | 07:22 PM
Samd's Avatar
Samd
Angry
So essentially I do need to replace the fuel pump? I was hoping not
Old Apr 22, 2011 | 08:09 PM
Mobile Auto Repair
That is correct.
Old Apr 23, 2011 | 02:10 PM
Samd's Avatar
Samd
ok i will replace it. now ive been shopping around, can i buy just the fuel pump and replace it inside of the module or do i need to buy the whole fuel pump and module? also are these stock pumps by walbro? i found a good deal on one but its only compatible with the walbro module. thanks again!
