Hi, New here Weird Issue
Old May 17, 2011 | 05:58 PM
Jason124's Avatar
Jason124
Default Hi, New here Weird Issue
Hi, I just purchased a 1998 Conversion van. Runs and drives Beautiful... most of the time. Heres the problem, I know the issue but im unaware on how i should go about fixing it. The computer on the fire wall has Three big plugs, probably 2 inches across. The one on the far left has a little bit of play to it. When I get it started there is not an issue, but if it vibrated on the ride to the store when i come out the thing wont start. No huge deal, just jiggle the cord and off I go. But I would like to fix it. Has any one had this problem? If so what should I do?
The Engine Is the 3.9 v6 with 105 thousand miles.
Thanks
Old May 17, 2011 | 06:12 PM
zawalis's Avatar
zawalis
sounds like the internal circuit board has a cold soldier joint. Just open that up and touch up the soldier (use flux) and it'll be good as new. The stresses on the connections on these boards are huge and eventually, the soldier can fail, leaving a "loose" or intermittent connection.
Steve
Old May 17, 2011 | 08:56 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Why can't it just be a loose connector? Start with the simple stuff. Get yourself a can of electrical contact cleaner. Disconnect the battery, remove the connector, spray everything with the contact cleaner, then repeatedly plug and unplug the connector several times. Make sure everything is dry, plug the connector in, and then reconnect the battery.
Old May 19, 2011 | 02:18 AM
zawalis's Avatar
zawalis
Good point. It's simple to try this. I read that one had play in it and then jumped to a conclusion. It could be dirty or loose.
Old May 21, 2011 | 05:35 PM
stev's Avatar
stev
This is a good product and I've used it already on the PCM contacts too.
Old May 24, 2011 | 10:17 AM
Jason124's Avatar
Jason124
Hey guys thanks for the replies. So I ended up taking it to a shop to have the check engine light looked at. I figured two birds one stone deal. Turns out the computer is bad. A bad solder. The mechanic said he ran it for one minute and it mis fired on cylinder 1 86 times. So a new computer looks like the answer. When I get it I'll put it in and let you guys know.
Old May 24, 2011 | 12:22 PM
zawalis's Avatar
zawalis
You *could* try to repair the computer's bad soldier. It may be simple and cheap.
Old May 30, 2011 | 12:59 AM
stev's Avatar
stev
True. Just use a sharp etching tool to break the PCB coating and lay in a fresh solder bead. My son did that for his 95 V6 Camaro. It worked well.
