9 MPG Gas Mileage Dodge Conversion 1989
Old Aug 8, 2011 | 05:59 PM
svitko's Avatar
svitko
Default 9 MPG Gas Mileage Dodge Conversion 1989
Hello,
I just purchased a 1989 Dodge Conversion Van, 8 cyl, 5.2 L, Automatic 4-spd, Regular Gasoline with overdrive. I'm getting 9-10 MPG and I drive highway 90% of the time. According to fueleconomy.gov I should get 16MPG highway and 13MPG combined.
Any ideas?
Thanks!
Steve
Old Aug 8, 2011 | 06:38 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
How many miles since it's last tune-up?
Have you done a compression test to see if the cylinders are leaking?
Old Aug 8, 2011 | 09:54 PM
landyacht318's Avatar
landyacht318
A couple things which have at one point or the other contributed to less than Ideal mileage on my '89.
O2 sensor. Do not use Bosch. NTK/NGK agrees with mopars.
2 wire coolant temp sensor out of whack
vaccuum leak.
Other things which have not effected me.
Dragging brakes, poor compression, lack of overdrive or lock up.
Bad wires/plugs distributor cap and rotor.
Use brass contact on the dist cap only. Aluminum is sub sub par.
Old Aug 9, 2011 | 05:23 AM
svitko's Avatar
svitko
I have no idea when the last tune-up was done, and no idea how to do the compression test. Sounds like a good place to start though - Thanks!
Old Aug 9, 2011 | 05:25 AM
svitko's Avatar
svitko
vaccuum leak.
How's your mileage now - are you getting a higher MPG than 9-10?
Thanks for the help!
