rear noise
Old Oct 23, 2011 | 12:59 PM
miguey's Avatar
miguey
Default rear noise
hi guys, well i have a 1988 dodge ram and awhile back i hit a huge speed bump and blew my shocks and i replaced them but when i hit a dip or small speed bump i can hear the noise from the back (idk if it made sense lol) well since i replaced the shocks what else can it be ? any bushing to check ?
Old Oct 23, 2011 | 01:07 PM
master tech's Avatar
master tech
Site Moderator & Tech
Make sure the shock bolts are not loose, springs or the exhaust tail pipe hitting the spring. Also check the spare tire too.
Old Oct 23, 2011 | 01:26 PM
miguey's Avatar
miguey
i'll check the shock bolts now , what should i check for in the springs? exhaust is good and no spare tire underneath
Old Oct 23, 2011 | 01:53 PM
miguey's Avatar
miguey
driver side:
http://imageshack.us/clip/my-videos/600/4xm.mp4/
passenger side:
http://imageshack.us/clip/my-videos/844/7p1.mp4/
Old Oct 24, 2011 | 09:19 PM
stev's Avatar
stev
Well, there are a few things in the back to look at.
- Are the gas tank straps secure?
- The fill neck to the gas tank?
- How are the rear door hinges?
- Rear universal joint alright? (could be the issue)
- The rear differential?
- Does this van have rear seats or a rear sofa bed?
- The jack by the rear door?
Nice recordings banging on the shocks.
Can you record the noise in the back either from the inside of the van or outside?
Old Oct 24, 2011 | 10:03 PM
Rusty93RamVan's Avatar
Rusty93RamVan
Could be the rear leaf spring shackles, the ones on my '98 make some noise.
I would call that van a '97 based on the fuel tank location and exhaust pipe exit to the left under the fuel door. What is the date of manufacture?
Old Oct 25, 2011 | 12:05 PM
miguey's Avatar
miguey
what is that? and it's a 1988
Old Oct 25, 2011 | 12:07 PM
miguey's Avatar
miguey
-yes
-it seem stable
-can't be the door hinges cause the noise comes from the floor
-what should i look for in the differential
-yes
- no
Old Oct 25, 2011 | 12:08 PM
miguey's Avatar
miguey
also check out the videos i posted so you can kinda hear the noises
driver side:
passenger side:
Old Oct 26, 2011 | 08:27 AM
Rusty93RamVan
My bad. You wrote 88 but I misread as 98. Time for glasses?
