Help
Old Jan 2, 2012 | 09:51 AM
anlake2's Avatar
anlake2
Default Help
Where is the Temp sensor, 1999 Ram Van 1500, 5.2 v8 Can any one tell me how to replace this sensor and where it is located..(
Old Jan 2, 2012 | 10:22 AM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Which temp sensor?
AC freeze detector
Intake air temp sensor
Temperature gage sensor
PCM coolant temp sensor
Old Jan 2, 2012 | 10:44 AM
anlake2's Avatar
anlake2
Default Temp Sensor.
Thank you for replying My temp gauge quit and I seem to have a hesitation when I take off. Replace water pump and alternator this week. Check engine light came on and parts store told me it was the Temp Sensor. Sorry not much of a mechanic.
Old Jan 2, 2012 | 10:49 AM
Mobile Auto Repair
Then you you might want to check that the IAT temp sensor connector behind the alternator and on the Intake is firmly plugged in. The PCM coolant temp sensor is behind/below the AC compressor. IF you have small enough hands you might be able to remove/replace with out moving the AC compressor but most likely you will need to pull the 4 bolts that hold it on after removing the belt and slide it forward. Use a deep well socket for either one of the sensors. You do need to verify WHICH temp sensor they are talking about.
Old Jan 2, 2012 | 12:18 PM
anlake2's Avatar
anlake2
This van was customised for a lift and somethings seem different I found a sensorn behind the altenator It is larger and has a cage with an element in it, any idea aout this Also I found a wire coming fron the same bundle with a broken element (notnattached and no cage on it Can I get a pic of these elements
Old Jan 2, 2012 | 12:23 PM
Mobile Auto Repair
Then single wire behind the alternator on the intake manifold is for the coolant gage on the dash. The PCM uses a 2 wire sensor closer to the AC compressor. Does that one have 2 wires or is a wire broke from it? Also the intake air temp sensor has 2 wires going to it.
Old Jan 2, 2012 | 12:24 PM
Mobile Auto Repair
If you can take and post a pic of what you are seeing that may very well help us to find where that one wire goes.
Old Jan 2, 2012 | 12:45 PM
anlake2's Avatar
anlake2
Default coolant gage
One has a singlenwire going to it.And my gage had quit working Itis just different then they sold us I will post pics when my son gets back. I really am greatful for your time
Old Jan 2, 2012 | 12:50 PM
stev's Avatar
stev
The wires going to these sensors are not the strongest. So be careful not to pull via the wires.
Old Jan 2, 2012 | 01:34 PM
anlake2's Avatar
anlake2
Can that coolant gage effect the hesitation in the motor and my milage
