Need help with trans
Hello guys new to the site and hoping for some help. I just bought a 2001 dodge ram van 2500 with the 5.9 and auto trans 219,000 on the clock and running strong my problem is the trans is stuck in limp mode I believe 3rd gear CEL is on took it to autozone and got these codes p1757,p1740 and p0748 I'm stumped because there so many I've googled some of these codes and I'm Thinkin I might need the ecu. Any help is greatly appreciated
From my research I think its flagging the TCC solenid switch in the tranny.
If these codes are same from a 1999 to 2001 and the transmissions are the same,
Code P 0748 Gov Pressure Sol Control/Trans Relay Circuits
Code P 1757 Gov Pressure above 3 psi in gear at 0 MPH
I found this during a web search:
Code P 1740 TCC Or OD Solenoid Performance
These are the codes you mentioned that I was able to find that apply to the trans I have in my Van but I do not know if they are the same in your year.
Since you have the codes, why not call a Dodge Dealer or two and see if they are willing to tell you what they are. Make sure you know what transmission is in your Van. Any Dodge dealer should be able to tell you by your Vin number.
Hope this helps,
Jason
Hope this helps,
Jason
Yea I ended up finding out the codes I talked to the p.o and he told me he already replaced one sensor in the trans and still the same limp mode then he told me he tried to have the PCM reflashed and it wouldn't take so I guess I need to have it rebuilt idk what route to go what do u guys think
You also have not told us what Model # of transmission you have in your van.
I personally do not want to jump to any conclusions, so again I would like more information. I just had my Pcm Rebuild by SIA electronics in Tilden IL. They will check your PCM for problems and if they do not find anything wrong with it then they will charge you something like $89. If they do have to repair it then they will charge you $199 but you will have a lifetime warranty on it as long as you own the vehicle.
Before I would do that I would do a little more investigation. You can end up changing a lot of parts and spending a lot of money that might not be necessary.
Jason
Trending Topics
You have not mentioned who attempted to re-flash the PCM? Was it the Dodge dealer? If you look at my posts in this forum you can see where I sent my PCM off for repair. Even if you buy a new one, it will have to be programed and they will need the Vin #number of your Van and the mileage before they can redo it. I posted the name and number of a company SIA electronics that will repair your PCM. If you go to a parts store you are going to pay close to $300 for a new PCM and it will still have to be flashed to match your vehicle.
It sounds like you are dead set on getting the PCM replaced. Maybe its the issue and maybe its not. Until enough information is provided I personally cannot help you other than the questions I have already posted in regard to your issue.
Jason
5.9 Gas engines had the 46RE trans,Diesels had had a version of the same trans....PCM problems are very common but I have not heard of much sucess with re-flashing, they usually just fail......I believe I would unplug the 8-pin connector at trans and see if there is any voltage..This would verify if fuses and relays are sending voltage...Most but not all PCM problems in my experience with dodge PCMs is on the ground side.....If there is no voltage, be sure and check fuses, relays and wiring first..
Brian
Brian
