Q for the pros
Old Mar 12, 2012 | 05:59 PM
rebelsurveyor's Avatar
rebelsurveyor
Question Q for the pros
Have a 2001 Ram Wagon with rear air. Noticed the front fan switch only blows air on the highest setting and not low or medium. I have a shop manual but the the A/C-heat section is a little over my head. Sounds like it could be a fuse, relay or switch. Don't have any sort of electrical test equipment so I'm down to parts changing. Any suggestions? Thanks in advance.
Old Mar 12, 2012 | 06:23 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Replace the blower speed resistor. It's mounted by two screws to the big black box under the hood on the passenger side, along with a flat 4-wire connector.
Old Mar 12, 2012 | 06:32 PM
rebelsurveyor
Man, that was quick. Thanks Alloro, I'll do it in the morning.
Old Mar 13, 2012 | 12:23 AM
stev's Avatar
stev
The rear HVAC unit in the 2000-2003 Ram Van is cheesy at best. The blower speed has settings and the AC blows out the bottom and the heat out the top. There is no blend level. I had to set this manually.
There is a resistor on the rear Denso HVAC unit on our van. The actuator is a yellow type made in TN, USA.
Old Mar 13, 2012 | 09:58 AM
rebelsurveyor
It's fixed. Thanks again for the help.
