Power door lock problem
HI,
I own a 1999 Ram 1500 Van. It is a Mark III conversion van. Just the other day, the power door lock remote worked fine. Then, I had some body work done, including new front passenger door and new cargo doors. The power door locks for the cargo door was taken out of the old door and installed in the new one.
the power door locks work great when using the switch in either of the front doors.
However, when I try to use the remote, nothing happens. I replaced the batteries in the remote, and still nothing.
Any ideas? The van finally looks stupendous (no more ugly stripes, no more cracked flares) and beefy. But, now the darn door lock remote doesn't work, it's always something.
Thanks for any help you can give me.
ok, I will check the fuse box. Um, any idea where the fuse box is located?
There is a fuse panel behind the front seats that was added by Mark III when the conversion was done. Don't yet know if that completely replaced the factory fuse box.
thanks again.
thanks again.
...Just the other day, the power door lock remote worked fine. Then, I had some body work done, including new front passenger door and new cargo doors. The power door locks for the cargo door was taken out of the old door and installed in the new one....However, when I try to use the remote, nothing happens. I replaced the batteries in the remote, and still nothing...
Rusty, yes, you make a good point. the power door locks do work, it's just that the remote doesn't work.
I looked at all the fuses and tried a key fob reprogram procedure that I found on the forum. the fuses are all intact and the reprogram procedure didn't work.
could the fob have gone bad? I replaced the batteries, like I said, but don't know how to test it.
ok, I retried the reprogram procedure. It started out working like it was supposed to, but there was no indication that the system received the signal from the fob.
I guess I will try a new fob.
