ram van wheelbases
1. turn ignition to off
2. ground the dark green program enable wire located in cavity one on the datalink
3. turn key forward to on. power door locks will lock/unlock.
4. push a button on key fob. doors will lock/unlock.
5. repeat for additional keyfobs
6. remove jumper wire.
7. turn ignition to off and remove the key
8. test the keyfob
I don't know how to test the remotes other than with this procedure. In theory a field strength meter should be able to indicate rf transmission but I don't know what frequency band these units operate on. There is a black box under the dash marked keyless entry (or similar). If you remove the engine cover and look up underneath the dash you can't miss it.
I would try removing and replacing the batteries in the remote and repeating the steps if this procedure does not work. Good luck!
8. test the keyfob
I replaced the batteries in the fob, and ran through the reprogram procedure. Thanks again for posting it.
Unfortunately, nada. So, I guess I will get a new remote and see if that works.
After that, I guess it's the receiver. I'll see if it looks okay, wouldn't know how to go about testing that.
Anyway, thanks for your help. At least now I know where all the pieces are.
