Vibration
how about crawling underneath and pulling hard on the drive line where the universal joints are.. any play in them will cause a vibration when driving only, and not when just reving the engine. A van that old may have never had the u-joints lubed, and they may need replacing. You can also try jacking up the rear wheels securely, blocking the front tires, or getting it to a garage on a lift, where you can run the van in gear, spinning the rear wheels and looking and listening for the vibration source from underneath.
I had a '95 B250 van that also vibrated ( I will call it chattered) while at freeway speeds. Not bad vibration, but a similar sensation as driving on the rumble strips on a highway... just not as pronounced, in fact it was barely noticeable by passengers unless I pointed it out. The chatter went away when I left off the acelerator, but would come back as I stepped on the gas. My transmission man suggested a can of a No-Slip additive in the tranny, and after about 100 miles the vibration stopped completely and never came back.
This has to be done with the parking brake set, the wheels chocked, and the tranny in neutral. If the tranny is is park there is stress on the driveline which will prevent any free play from showing up.
