from tilt to non-tilt steering columns
Old Apr 25, 2012 | 02:15 AM
89b150's Avatar
89b150
Default from tilt to non-tilt steering columns
hello;
I have a broken turn signal switch.
I would like to know if a non-tilt steering column can be easily put in a van that has a tilt-steering column.
The reason for asking about the column is because I am able to pick up a van that comes with a non-tilt column. (My present column is tilt.)
This van also comes with parts that I can make use of, such as a windshield and a couple of doors.
From what I have read, the tilt turn signal switch is different from the non-tilt turn signal switch, hence the reason for the column change.
Would the electrical connections give me a problem.
Thank you,
89b150
________________________________
1989 150 LE
318, Auto
Old Apr 25, 2012 | 04:12 AM
blackvan's Avatar
blackvan
Originally Posted by 89b150
hello;
Thank you,
89b150
1989 150 LE
318, Auto
Hi, It looks like you are correct, the replacement part lists as tilt vs non-tilt. If the price is right I would buy the van for the doors and windshield anyway ($600 in parts) The switch you want is only $52.79 + shipping, maybe even cheaper for a used switch on Ebay.
http://www.rockauto.com/catalog/x,ca...,parttype,4832
Old Apr 25, 2012 | 06:17 PM
89b150's Avatar
89b150
thanks for the quick response blackvan.
Oddly enough, the price of this van is $600.00. It has a 3.9 Litre V-6.
He put on the new head gaskets together with gasket silicone, therefore they need to be done again.
The body, according to the ad is in "near mint" condition, with only one small rust spot.
And, it is black.
thanks,
89b150
