96 Dodge b3500 15 pass.Tranny Problems
Old Apr 29, 2012 | 07:16 PM
ramrod000's Avatar
ramrod000
Default 96 Dodge b3500 15 pass.Tranny Problems
Hey guys,I have a 1996 Dodge Van B3500 15 passenger with a 5.9L. The tranny started slipping real bad and it was out of the blue.So I changed fluid and filter and wow like New,then after about an hour slipping real bad again.Tranny was perfect and just one day started slipping real bad,can anybody help ? Never gave any sign of slipping or anything before.Maybe governor Pressure solenoid? Help please
Old Apr 30, 2012 | 10:39 AM
iodj44's Avatar
iodj44
Ramrod000
Must say does not sound good, how did the fluid smell and was it bright red?
Double check you filled your trans with the proper fluid as the wrong fluid will
destroy the tranny in short order. Your tranny operated correctly after the fliud
filter change and now is slipping again is a bad sign.
Personally I would check the level again with the tranny warm in neutral on a truly flat surface, hopefully it my be a few quarts low. Also be careful NOT to overfill as that can damage the trans as well.
Old Apr 30, 2012 | 10:47 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Did you adjust both bands properly when you changed the fluid/filter?
Old Apr 30, 2012 | 01:08 PM
ramrod000's Avatar
ramrod000
I used atf 4 and the fluid level was perfect also did not mess with the bands.This morning went to bring it to my mechanic and just about made it there, once I was there it **** the bed it wouldnt even engage forward or rev. So Im in the process of a rebuild. Gotta suck it up and face reality the tranny is toasted.Thanks a bunch guys for your imput i really appreciate it.Thanks again oh and the cost of rebuild is around $2300.00 sound Fair ??
Old Apr 30, 2012 | 05:13 PM
alloro's Avatar
alloro
No, you're getting hosed. Somewhere between $1500 and $1800 would be fair and normal.
Old May 1, 2012 | 11:28 AM
iodj44's Avatar
iodj44
Sorry to read it is toast may be a good idea to spend 30 bucks and a hour of your time to install a trans cooler
I notice my engine ran about 10 degrees cooler(while towing) after installing my trans cooler, good insurance for the trans.
Best of luck hope you can get that rebuild price down.
Old May 1, 2012 | 05:15 PM
Rusty93RamVan's Avatar
Rusty93RamVan
Originally Posted by iodj44
...may be a good idea to spend 30 bucks and a hour of your time to install a trans cooler...
That vehicle already has a factory installed transmission cooler just ahead of the radiator.
Old May 1, 2012 | 05:47 PM
iodj44's Avatar
iodj44
My mistake, thanks.
Old May 1, 2012 | 05:52 PM
iodj44's Avatar
iodj44
Just a thought should my 96 3500 have come with one as it did not have one when I purchased it ~4 years ago?
