2000 1500 V6 timing?
Subscribe
May 13, 2012 | 03:53 PM
can anyone please tell me what the proper timing is on my 2000 Ram Van 1500 with a V6 engine . The book says look under hood, the hood says look in book ,can you believe it. ive got a major loss of power and trying to eliminate things.Any help welcome .Thanx Jimship
Reply 0
May 13, 2012 | 10:52 PM
The timing is computer controlled and cannot be adjusted.
Have you tested your fuel pressure yet?
Reply 0
May 13, 2012 | 11:54 PM
Yea, I was surprised that is what the Chilton said...
https://elibrary.mel.org/validate?ur...ch%3Fdb%3DCHLL
use a letter and then 12 numbers -- q123456789012
Reply 0
May 16, 2012 | 12:26 AM
No I have not, but will next. I knew I couldnt adjust the timing,i wanted to make sure the chain has not jumped. But thanks for the fuel pressure suggestion.
Reply 0
May 16, 2012 | 12:52 AM
The timing chain symptoms for this 3.9L Magnum engine are a rattling noise coming from the timing chain case. I don't believe these use the plastic coated gears like the old ones so unless your motor has over 200K I think you should be looking elsewhere for the issue.
On every '70 - '90 V8 timing chain that I have replaced (with plastic gears) the symptoms are very sudden onset, and engine will either not start or will just barely run at all.
Reply 0
May 16, 2012 | 01:03 AM
Presumably the computer is smart enough to know what wrong with it if its that far out of tolerance. Have you pulled codes off this yet?
Reply 0
May 20, 2012 | 04:20 AM
i have. no codes checking fuel pressure cylinder comp., and cat.converter.let you know what i find. thanks. I have check fuel pressure VERY high also i am getting vacume at throttle body when in idle witch the book says i should not.Any ideas. Thanks
Reply 0
Subscribe
