Mis-fire in 1,3,5
Old Jun 26, 2012 | 11:30 PM
jimbo111@yahoo.com's Avatar
jimbo111@yahoo.com
Default Mis-fire in 1,3,5
I'm getting mis-fire codes in 1,3,5 and wonder if anyone has solved this problem. I can't believe it's the cap, or the wires, there only 1 year old. One wire yes, 2... maybe, 3 on the same side, no. I'm thinking fuel rail/injectors, anyone have any thought. Recently fixed a vacuum leak that cause the AC selector to not work, fixing it did make the trans shift GREAT, but hasn't helped the mis-fire codes.
Any/all help appreciated.
Thanks in advance.
Old Jun 27, 2012 | 11:16 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Welcome to my nightmare!
I spent many years fighting this very problem. I replaced plugs, wires, cap, rotor, ECM, sensors, coil, crank sensor, and the pick-up coil. A compression test showed all cylinders to be good. Nothing helped until I switched over to a high end plug wireset. Even then I had to be careful with how the plug wires were routed and I used many extra wire looms to help keep the plug wires from touching each other.
Old Jun 27, 2012 | 08:26 PM
jimbo111@yahoo.com
I'll get high perf wire set and run it very carefully.
Thanks so much for your in site and input.
Jim
Old Jun 29, 2012 | 07:05 PM
Rusty93RamVan's Avatar
Rusty93RamVan
I have done exactly as Alloro (as near as I can figure) using the same high-end Accel wire set. I even have them wrapped in convolute, and I have followed the TSB for re-routing the wires from the stock locations. None of the wires touches another.
I STILL get random misfire codes. Don't be disappointed if replacing your wires does not solve your problem.
But I hope it does.
Old Jun 30, 2012 | 12:18 AM
BilltheDrummer94's Avatar
BilltheDrummer94
I know you guys probably don't want to hear from me on this thread too but maybe we can solve everyones problems sooner or later.
The problem being the PCM is still iffy in my situation. It was just reprogrammed and I'm still having problems.
After doing all of the other things I've done so far I'm thinking it's one or a combination of these things:
MAP sensor going bad, vaccuum leak or something related, clogged cat, or somthing else significantly worse.
As far as the vaccuum theory goes, immediately after startup, I hear this whistling type sound from the drivers side dash. Also when adjusting the A/C switch sometimes, I hear this sound kinda like shrinking. It's like a sucktion sound. It's all interconnnected isn't it?
Any help is appreciated.
Thanks, Bill
Old Jun 30, 2012 | 11:19 AM
Rusty93RamVan
Originally Posted by BilltheDrummer94
...As far as the vaccuum theory goes, immediately after startup, I hear this whistling type sound from the drivers side dash. Also when adjusting the A/C switch sometimes, I hear this sound kinda like shrinking. It's like a sucktion sound. It's all interconnnected isn't it?
Thanks, Bill
The whistling sound you probably hear is the selector switch for the HVAC. They all seem to do that as the plastic shrinks over the years. The sound you hear is the vacuum leaking out a little when the switch is not settled perfectly on the exact position indicated on the dial face.
Wiggle the switch selector slightly back and forth once you've landed on the selection you want and the vacuum sound will stop.
What was so wrong with cable operated HVAC systems? I hate all this vacuum crap, beginning with my '77 240D Mercedes all the way up to my '98 B1500. All these vacuum controls really annoy the crap out of me.
Old Jul 1, 2012 | 04:48 PM
funair02's Avatar
funair02
Default hmmmmm
SUBJECT:
5.2L Engine - Crack in Cylinder Wall
MODELS:
2002 (AB) Ram Van
NOTE: THIS BULLETIN APPLIES TO VEHICLES BUILT PRIOR TO JANUARY 1, 2002.
DISCUSSION:
Customers may complain of one or more of the following:
1. Fluid low in coolant reservoir.
2. Coolant smell in the exhaust.
3. White smoke coming from the tailpipe.
4. MIL (malfunction indicator light) on.
Technicians may notice one or more of the following:
5. Misfire on No. 8 cylinder with the MIL on.
6. Cracked or broken spark plug in No. 8 cylinder.
The DRBIII
® can be used to confirm that a misfire on No. 8 cylinder is the cause of
the MIL “on” condition. Following the applicable procedures in the service manual
(Publication No. 81–370–0255) a cooling system pressure test should be conducted
to determine whether or not the system will hold pressure. If the pressure bleeds
off, the cylinder head should be removed (Section 9, Engine 5.2L, page 9-83) and
checked for a crack in the No. 8 cylinder wall (Fig. 1).
NOTE: IF THE MIL IS NOT “ON” AND/OR THE COOLING SYSTEM PRESSURE
TEST MEETS SPECIFICATIONS, IT IS UNLIKELY THIS CONDITION EXISTS AND
DIAGNOSTICS TO DETERMINE OTHER CONDITIONS SHOULD BE PERFORMED.
NOTE: IF A BORE SCOPE IS AVAILABLE THE TESTS ABOVE MAY NOT
BE NECESSARY. ROTATE THE ENGINE UNTIL THE PISTON IN NO. 8
CYLINDER IS AT BOTTOM DEAD CENTER AND, USING THE BORE SCOPE,
CHECK FOR A CRACK IN THE CYLINDER WALL.
7. If the crack exists, follow current warranty policies and service procedures
for repair or replacement.
Old Jul 1, 2012 | 09:53 PM
funair02's Avatar
funair02
I've also have been told the timing chain may be sloppy causing this condition...
there is so much that can cause this - it will drive you bonkers!
I am almost starting to think, if you get these codes and can't make them go away, you need a new long block...
Good luck
Old Jul 2, 2012 | 05:40 AM
gazza101's Avatar
gazza101
How does it drive? what gas do you use?
Old Jul 3, 2012 | 12:29 AM
BilltheDrummer94
We need to make a check list for this problem. If anyone is interested I'll post what I've done so far.
About the timing chain theory, that's kinda what I was thinking too. Would it get better once you accelerated? Because apparently my misfire dissapears above idle. I did have the water pump changed and the first time I myself opened up the doghouse the oil tube was disconnected. Maybe something to do with the chain after changing out the water pump?
I don't understand alot of engine mechanics but I know some haha.
