Ram Van losing power
Old Sep 5, 2012 | 03:26 PM
splice1's Avatar
splice1
Default Ram Van losing power
Hi Everyone, Got some great help here before when my van would not idle. Replaced the IAC and the TB sensor, the van has run great for almost a year. All of a sudden while I am driving the van loses power and start to back fire. When I pull over, I can rev the engine fine. Put it in gear, and a big loss of power. Limped home today, and was wondering if I should clean the IAC, or do the finger test? Any input would be greatly appreciated.
Old Sep 5, 2012 | 04:36 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Based on the symptoms you've described your fuel pump could be on it's way out.
Old Sep 5, 2012 | 07:23 PM
splice1's Avatar
splice1
Would the fuel pump cause the van to backfire?
Old Sep 5, 2012 | 09:09 PM
alloro's Avatar
alloro
Yes, the lack of fuel results in a lean condition and a lean condition will cause backfiring.
Old Sep 6, 2012 | 06:58 AM
splice1's Avatar
splice1
Thanks for the information Rich!! Is the fuel pump a tough job? Will search sight for any information on how to.
Old Sep 6, 2012 | 11:52 AM
alloro's Avatar
alloro
It's not hard, just slightly time consuming. It's also a bit stressful because of the fear of explosion factor.
Old Sep 6, 2012 | 05:18 PM
splice1's Avatar
splice1
Any place I can get directions on how to replace the fuel pump for a 2003 van? Is the fuel pump in the fuel tank? Could it just be the fuel filter? Thanks
Old Sep 7, 2012 | 07:14 AM
splice1's Avatar
splice1
Anything else I should check before I do the fuel pump?
Old Sep 7, 2012 | 07:37 AM
landyacht318's Avatar
landyacht318
Has the computer stored any trouble codes?
I'd prefer to see measured low fuel pressure before replacing the fuel pump module
Old Sep 7, 2012 | 04:39 PM
Poagman's Avatar
Poagman
On this model can you disconnect the fule pump conenctor under the body near the tank?
If so you can do like me and apply power to the pump directly with a power source to see if humms or shows signs of life.
If so, there is something keeping the pump from turning on, not a defective pump.
