Headers for near-stock 5.2L 318 (1991)
Old Apr 2, 2013 | 06:41 PM
Poagman's Avatar
Poagman
Default Headers for near-stock 5.2L 318 (1991)
91 B150 RamVan w/5.2L 318ci auto - Please provide links to recommendations.
I need to buy new exhaust and was thinking two mufflers to avoid a cross-pipe.
1 - Benefits/drawbacks of a muffler per header?
2 - I want low-end torque
3 - Volume/sound doesn't matter
4 - If I go straight from header to muffler, what size in/out should I have on the muffler to ensure good low-end torque?
5 - What sizing would I go for if I wanted more power at higher RPM's
Old Apr 3, 2013 | 08:05 AM
iodj44's Avatar
iodj44
Before you start consider how loud headers will be underneath the doghouse
heat will also be a concern. Myself I think the sound may be more of a issue
than the floor getting warm.
Old Apr 3, 2013 | 11:37 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Ceramic coated headers will reduce both noise and heat. On the flipside, they are more expensive.
Old Apr 3, 2013 | 01:10 PM
landyacht318's Avatar
landyacht318
Stock 318's don't achieve enough rpm for headers to have any performance benefit anyway.
I've got a single Flowmaster 50 series behind a magnaflow Cat. Sure sounds faster.
It isn't.
Old Apr 4, 2013 | 12:55 AM
blackvan's Avatar
blackvan
Old Apr 4, 2013 | 10:53 AM
iodj44's Avatar
iodj44
In my experience you should also get you hands on a torch to heat the
bolts before trying to remove them. I have done my share of drilling out
and tapping after breaking a exhaust manifold bolt.
Old May 11, 2018 | 02:05 PM
Poagman's Avatar
Poagman
Default Update
I went with Hedman Hedder PN 79036 (ceramic coated). I got 70 off coupon code making them $407. then 20 more off for being backordered for a month.
i havemt put them on yet. in the past few months i aquired a 318 block, msd atomic efi, hvc coil, 6al controller. Looks like I'm doing more than I initially thought
