ECM part number
Old Mar 28, 2014 | 02:32 PM
Cooter5769's Avatar
Cooter5769
Default ECM part number
I'm ordering a PCM and I need the part number i can't get into the PCM to get the number what should I do ?
Old Mar 28, 2014 | 02:49 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
The number is on the outside of the PCM case, not the inside. Look on the big white sticker for a number that ends in a double letter like: AA, AB, BE, etc.
Old Mar 28, 2014 | 09:46 PM
stev's Avatar
stev
DUE NOTE: The PCM is not the same for each Ram Van.
The 3.9L, 5.2L and 5.9L are different PCM p/n's. AND each has sub-extensions within the PCM series due to the year and transmission type. Also, the different frame type dictates if 15-inch or 16-inch rimes and tires are used for the PCM to control the ABS of single or dual piston calipers. Talking about ABS, some PCMs control at wheel ABS vs. the standard rear ABS only systems.
So, just ordering a PCM for a Ram Van isn't all that simple. CARDONE can match your PCM p/n. They have a good warranty and pricing.
Old Apr 3, 2014 | 10:32 AM
Cooter5769's Avatar
Cooter5769
I worked for Chrysler and I have been a mech for over 20 yrs. I need help getting the correct part number from my vin.
