Crazy question of the day: Hydrometer
Old Aug 3, 2014 | 03:47 PM
sparkzz's Avatar
sparkzz
Default Crazy question of the day: Hydrometer
I ordered a floating ball hydrometer off Ebay. When I got it, all the ***** were in the top, and therefore, out of sequence. I assume each individual colored ball is engineered to float at a certain specific gravity. Now for the question: does anyone know the order of how the colored ***** are supposed to be stacked in the tube.
Thanks.
Old Aug 3, 2014 | 03:52 PM
You talking about the kind you fill with liquid or the kind you use for beer/wine making?
Old Aug 3, 2014 | 04:16 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Does ebay have a picture that you can use to put the ***** back in order? If not maybe the seller can help you with this.
Old Aug 3, 2014 | 04:26 PM
sparkzz's Avatar
sparkzz
I should have noted this is for a lead acid auto battery. On the package is says the sequence, top to bottom, is: Gray, Orange, Green, Blue.
Unfortunately, the ***** in this one are colored: Gray, Red, Yellow, and Black.
Old Aug 3, 2014 | 04:29 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Not sure why you would buy that kind off eBay, because for less than $3 you can get the much better Prestone scale/pointer type tester over at most any auto parts store.
But to answer your question, the colors have no meaning other than to make them easier to see in contrast to each other. Your concern will be with how many are floating and how far up the tube they rise. Did it not come with instructions?
Old Aug 3, 2014 | 04:44 PM
alloro's Avatar
alloro
Different application, same theory. The colors mean nothing, it's the number of floating ***** that matter.
Next chance you get grab one of these instead.
http://shop.advanceautoparts.com/p/a...2059/6283713-P
Old Aug 3, 2014 | 04:53 PM
sparkzz's Avatar
sparkzz
Ok -- Thanks for the info. Just giving in to internet laziness - it's easier to order it and have it shipped, than it is to burn gas and fight traffic.
Old Aug 3, 2014 | 05:00 PM
stev's Avatar
stev
If you sign up for email deals from AdvancedAuto, they send you coupons for 15% or 20% or free shipping or $10 of every $100 spent. Ususally though, they are higher priced compared to RockAuto.com
Old Aug 3, 2014 | 08:00 PM
landyacht318's Avatar
landyacht318
The floating ball hydrometers are the most ridiculous tool on the planet.
The plastic hydrometers that claim to be temperature compensated, are not.
often it is impossible to remove the bubbles from the float needle and it will yield higher than actual results.
The best Hydrometers are the glass turkey baster sytle with a glass float, and ones which have a thermometer on it calibrated to tell you how many 0,00x to add or subtract from the reading are a Zillion times more accurate and precise.
Do not waste money or time using anything else.
Amazon.com: OTC 4619 Professional Battery Hydrometer: Automotive Amazon.com: OTC 4619 Professional Battery Hydrometer: Automotive
Rinse it promptly after use.
And may your specific gravity be in the green
