reddog67 94 Ram B250 van ignition
Old Oct 1, 2014 | 10:01 AM
reddog67's Avatar
reddog67
Default reddog67 94 Ram B250 van ignition
My 94 Dodge Ram B250 won't start. Engine cranks, no fire to distributor, apparently no fuel either. Any suggestions?
Old Oct 1, 2014 | 02:07 PM
daguvena88's Avatar
daguvena88
Maybe a bad ASD relay issue, possibly a bad ECM/PCM (computer).
Getting a Check Engine light?
Old Oct 2, 2014 | 08:36 AM
reddog67's Avatar
reddog67
NO ck eng light, but no ck eng light when you first turn on ignition. Idid ck 4 relays, 12v at pins 30 and 86 but one relay also hat 12v on pin 85. Bad ground I'll pull that relay today and temp jump 30-87 to see if that helps.
Old Oct 6, 2014 | 10:50 AM
reddog67's Avatar
reddog67
Exclamation Still Searching for the Problem
I jumped the relays and got 12v to ign coil, fuel pump came on and power to injectors. Still no fire from distributor. The only fuse panel I've found is in glove box.
Any suggestions, all help would be appreciated.
Old Oct 7, 2014 | 07:12 AM
daguvena88's Avatar
daguvena88
bad distributor, high tension wire to coil pack, or the coil pack itself?
possibly Crank Position Sensor (CPS) but unlikely since you're getting power at the fuel pump, etc.
http://troubleshootmyvehicle.com/chr...t-a-no-start-1
Old Oct 7, 2014 | 11:04 AM
nibroc's Avatar
nibroc
I 2nd the ECM----'bout $60 from autozone
Old Oct 8, 2014 | 07:58 AM
daguvena88's Avatar
daguvena88
If he's getting power by jumping the ASD relay, wouldn't that kind of rule out the ECM/PCM? I suppose it could be intermittantly faulty/finicky.
I'd troubleshoot all ignition-related components downstream of the ASD relay. As alloro here on the forums has pointed out countless times, components like the high tension leads can provide inconsisent performance.
Old Oct 9, 2014 | 08:27 AM
reddog67's Avatar
reddog67
Default reddog says THANKS
Thanks for all the good info about trouble shooting coil, crank position sensor I'll run those test this weekend or fist of next week and give ya'll a report.
