transmission problems
Old Apr 24, 2015 | 12:26 PM
jawinder's Avatar
jawinder
Default transmission problems
I have a 1999 dodge ram 1500 van with a 5.2 L and a 46RE trans. The trans is having problems shifting correctly. But, not every time I take off. Most of the time it goes through 1st and 2nd ok, and then I will have to ease it into neutral and back to drive and It catches the other two or three gears. What will fix this? shift solenoid and pressure sensor? Please help......
Old Apr 24, 2015 | 01:16 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
If it's been close to 30K miles since the last fluid/filter change and band adjustments, then I would start with those.
Old Apr 26, 2015 | 08:29 AM
jawinder's Avatar
jawinder
I was thinking of doing that anyway, but I was really wondering if when I have the pan off, would it be a good idea to change the shift selenoid and the pressure sensor?
Old Apr 28, 2015 | 12:01 AM
master tech's Avatar
master tech
Site Moderator & Tech
If you shift thru 1st and 2nd gear fine and if you continue to drive to 40 to 50 mph, will the transmission upshift to 3rd gear? If it does, look at the kick down cable first and if that is good. Then order a transmission seal kit.
