HELP! Problems with flashers / relay?
Old Jun 10, 2015 | 02:43 PM
mickedeville's Avatar
mickedeville
Default HELP! Problems with flashers / relay?
HELP!
When i was on a litle trip with my 1988 b250 Nomad van today the flashers stopped to work.
Nothing happens when i try to flash right or to the left.
Im also without high beam.
When i drag the flash/highbeam lever towards me the highbeam works as long as i hold the lever, but the highbeamlight does not stay there like it should. Not even with the ignition ON.
My only troubleshooting as yet is controlled glass-fuses inside the right side dashboard, and they seems to be OK.
Can this problem be caused by a broken Relay?
If YES, exactly where do i find this relay?
Where should i begin to troubleshoot this problem?
Would be thankful for help with this !!
/ Best regards / Mike sweden
Old Jun 10, 2015 | 03:24 PM
Soulds like a multi function or turn signal switch problem.
Old Jun 10, 2015 | 03:36 PM
mickedeville
how do i know if the problem is the turn signal switch?
how do i troubleshoot it?
Old Jun 10, 2015 | 03:42 PM
It's probably worn out. You can get a new switch from rock auto. Requires removing the steering wheel to access.
Old Jun 10, 2015 | 04:06 PM
mickedeville
Okay thank u for the advice , its funny,, maybe 30 minutes before it happened, I thought to myself that the lever felt worn and looseness
I changed steeringwheel a week ago and it came a little bit wrong turned, so i should have had to release it anyway, so its nod that bad
Hope it solves my problem
Old Jun 10, 2015 | 07:20 PM
mickedeville
Do you think its necessary to buy both the "lever" and the turnsignal switch, or just the turnsignal switch behind the steeringwheel??
lever / cruisecontrol, washer, turnsignal
turnsignal switch
Old Jun 11, 2015 | 01:50 AM
landyacht318's Avatar
landyacht318
On my '89, there is a High/low dimmer switch on the base of the steering column. Next to the ignition switch.
There is a rod which comes down from the turn signal lever and activates high or low beam.
I took mine apart and cleaned the contacts, stretched the springs and lubed it so that full function returned to the switch.
I no longer have any major current running through this switch. This switch now just controls relays so i can feed the headlight bulbs alternator voltage rather than 2 volts less.
Much brighter.
Old Jun 11, 2015 | 08:30 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Get them both. You don't want to have to take it apart again.
Old Jun 11, 2015 | 10:42 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Too late, he already had it apart last week.
