No Blinkers on my 98 Ram Van
Old Sep 15, 2015 | 07:58 PM
blackvan's Avatar
blackvan
Old Sep 15, 2015 | 08:21 PM
toddbowie's Avatar
toddbowie
Thanks, I'll stop by tomorrow and see what they say. Maybe there is a ground that wasn't re-hooked back up.
Old Sep 16, 2015 | 01:39 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Originally Posted by toddbowie
Replacing a tranny? I guess anything's possible. I just hate to keep buying stuff to throw at it.
They have to get in it to test drive it as well as adjust the shift linkage after. I just meant getting in or out of the driver's seat the mechanic could've been a bit to rough on the switch.
Old Dec 16, 2015 | 05:22 PM
rush1981's Avatar
rush1981
don't know if you solved your problem yet but the fuse marked hazards under the hood control the blinkers too. I found out when my starter/ac fuse blew and van would not start so I took the hazard flasher to replace the ac fuse (both 20 amp) just to get the van started but then my blinkers would not work. I have a 98 1500 van and am having a problem with ac/starter fuse blowing when I turn on ac
