No Blinkers on my 98 Ram Van
Old Sep 13, 2015 | 03:17 PM
toddbowie's Avatar
toddbowie
Default No Blinkers on my 98 Ram Van
I have a 98 1500 Ram Van. After it was in a shop to have the tranny replaced, the blinkers and hazards don't work. I think that is just a coincidence. Didn't see a flasher relay under the dash. Is it plugged into the fuse box or is it somewhere else?
Old Sep 13, 2015 | 08:40 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
It's in the dash end panel fuse box. It looks like a big square relay but except that it's blue if it's still the OEM one, not black.
Old Sep 13, 2015 | 09:26 PM
toddbowie's Avatar
toddbowie
Thanks Alloro. Is there any way to bench test it or do I just have to buy a new one and hope for the best?
Old Sep 14, 2015 | 10:53 AM
rsdata's Avatar
rsdata
I would inspect the light sockets... rusty sockets can play havoc with the lighting circuit
Old Sep 14, 2015 | 11:01 AM
alloro's Avatar
alloro
You could setup the electrical to bench test it, but it's not really worth the time to go through all of that trouble to save 20 bucks.
http://www.rockauto.com/catalog/rafr...parttype=10139
Old Sep 14, 2015 | 08:03 PM
toddbowie's Avatar
toddbowie
Found one at NAPA for $17 and it will be on tomorrow morning. The strange thing, if I heard him right, is he mentioned it is a relay for blinkers, flasher and something about the water pump??? Almost positive that is what he said I'll ask them when I pick it up. Would that make any sense?
Old Sep 15, 2015 | 11:00 AM
alloro's Avatar
alloro
Don't know about the water pump, but the flasher unit/relay is a combination unit that handles both the turn signal and the 4-way hazard flasher circuits.
Old Sep 15, 2015 | 06:23 PM
toddbowie's Avatar
toddbowie
Well I replaced the relay and still no blinkers or flashers. The fuse is fine (the one marked combo flasher). Not real sure where to check next. I can;t see it being a bulb ground as none are working.
Old Sep 15, 2015 | 07:40 PM
alloro's Avatar
alloro
Maybe they broke the turn signal switch.
Old Sep 15, 2015 | 07:54 PM
toddbowie's Avatar
toddbowie
Replacing a tranny? I guess anything's possible. I just hate to keep buying stuff to throw at it.
