Does the 1994 Ram B350 have a full frame?
Old Oct 12, 2015 | 11:16 PM
Crash1's Avatar
Crash1
Question Does the 1994 Ram B350 have a full frame?
I just bought a 1994 Roadtrek 190 Independent class B motorhome on a Ram350 chassis and was told it is can't tow much because it's a unibody. This seems a little odd to me, it has a 7484 lb GVWR. Thanx
Old Oct 17, 2015 | 10:08 PM
SteveR's Avatar
SteveR
You can get a hitch for this van and the install should be OK as long as you do not have a trunk installed under the rear of the van. My 1991 Dodge has a "frame" but its welded to the body. You could never replace the frame so they are sort of a unibody.
Regards, Steve
Old Oct 17, 2015 | 11:19 PM
Crash1's Avatar
Crash1
Thanx for the reply Steve, I was wondering if the regular B-350 van is different from the Roadtrek van. The owner's manual for the Ram van says with a 390 gear it can tow an 8500 lb trailer. The Roadtrek I have can't tow very much.
Old Oct 18, 2015 | 01:15 AM
SteveR's Avatar
SteveR
The Roadtrek's are pretty heavy. Both my 1991 and my parents 2004 are overweight on the front axles when they are loaded with fresh water.
I would take it to the scales when they aren't manned to see where you are at for weights on each axle and combined.
Old Oct 20, 2015 | 11:47 PM
Crash1's Avatar
Crash1
The GVWR on the door post is 7485 lbs
It weighs 6534 lbs with full fuel, empty tanks & no driver, propane or supplies.
This appears to leave me with a useful load of 951 lbs.
Since the 3 of us weigh about 375 lbs, we can only add another 576 lbs before we exceed the GVWR?? Ouch! Does this sound right?
