Rear drum brakes red hot after replacing shoes
Old Oct 31, 2015 | 11:43 PM
Originally Posted by zzbb
First off, thanks for your quick replies!
@jkeaton OK I've taken this part off. I have not cut it open yet, but air does go through both ways. Still, it could have a problem inside and as long as I have it off I will replace it.
Naturally nobody has it in stock, so tomorrow or Monday will tell the tale.
Thanks again I do appreciate your help.
Worth checking. Not saying this is the solution. But rule out all possibilities. Good luck!!
Old Nov 5, 2015 | 06:04 PM
zzbb's Avatar
zzbb
An update: I think it may be fixed! The hose finally came in at the parts store, I put it on, and have test driven it several times.
So far no burning heat on that side now. Both sides are equally hot, but what I would call normal hot. Not so hot you'd burn yourself. Not as hot as it was before.
So I believe I"m good to go.
So, THANKS!!!!!
Thanks so much for the suggestions. I might have eventually gotten to it myself, but I was frustrated. Sometimes a fresh look gets things going.
Very glad I asked.
Old Nov 5, 2015 | 08:02 PM
Glad it worked out.
