NEWBIE: Tranny hose replacement
Old Dec 9, 2015 | 04:01 PM
cinemaphonic's Avatar
cinemaphonic
Originally Posted by jimbo74
ok, so from your picture, the green circled area is the nut you are going to have to do, it will require 2 wrenches, the side on the left, wont move, but needs to be held in place allowing the side on the right to unscrew - it is a compression fitting
the part of the pic circled in red, is a snap in fitting, you depress those 2 tangs sticking out, and the whole thing will just pull out of the hole
Ok that's starting to make more sense. So will this be replacing the entire assembly. I will basically need this whole thing in this link?
From what I've read one of these lines (either return or supply) will be pressured. Do I need to worry about that, or just expect normal drainage?
Thanks again.
Old Dec 9, 2015 | 04:08 PM
jimbo74's Avatar
jimbo74
that is what I found also, but from the pic you have above, just that piece comes off... if you can't find just that small section, then the next step would be to replace the whole hardline as well, as that linked part is 1 solid piece, that doesn't have the hose as it's own piece
Old Dec 9, 2015 | 06:19 PM
funair02's Avatar
funair02
this place can make any hose or find you any hose
http://www.goodyearrubberproducts.com/
look up a local one or call the one above
Old Dec 10, 2015 | 11:00 PM
jimbo74's Avatar
jimbo74
Have you tried the dealership?
The official name is a transmission oil cooler return or pressure line. I am not sure which one it is....
