1987 b250 cranks but wont start
Old Aug 8, 2016 | 12:23 PM
1990B150's Avatar
1990B150
Default 1987 b250 cranks but wont start
Hopefully I'll get some feedback here... I picked up a 1987 B250 Xplorer Camper Van. It has an electrical problem, cranks but won't start.
No power to dash with the key turned to ON. Blowers work, and some of the cabin lights, but no dash lights and no radio. Cranks and the "brake" light in the speedo lights up but that's it.
Ordered an ignition switch... seems like the most likely culprit. I don't think it has TBI, so I don't think it has an ASD. Waiting for the repair manual to arrive, I'm assuming this switch is on the column? Any tricks to replacing it or suggestions about what else might be causing this?
Old Aug 9, 2016 | 09:57 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Actually a more likely (and less expensive) culprit is a burnt fusible link that powers the ignition switch.
Old Aug 9, 2016 | 10:16 AM
1990B150's Avatar
1990B150
The burnt link would cut power to the dash?
Old Aug 9, 2016 | 10:20 AM
alloro's Avatar
alloro
It would cut power to the ignition switch so that when you turn the switch on the dash would remain dead.
Old Aug 9, 2016 | 10:23 AM
1990B150's Avatar
1990B150
But allow power to cabin lights and cranking? The light by the fuse panel in the glove box is on, for example.
Old Aug 9, 2016 | 12:02 PM
alloro's Avatar
alloro
All are different circuits. There are 2 ignition circuits, both fed by fusible links. If one is good and one is not, then some items controlled by the ignition switch (like cranking) will work while others will not (like gauges).
Old Aug 9, 2016 | 12:54 PM
1990B150's Avatar
1990B150
I'll check them when I get back to the vehicle. You just cut open the bundle behind the booster, correct? Also, do you know if the ASD relay is specific to fuel injected vehicles?
Old Aug 10, 2016 | 11:17 PM
alloro's Avatar
alloro
Correct
and
Yes (fuel injection and throttle body injection)
Old Aug 11, 2016 | 09:31 AM
1990B150's Avatar
1990B150
Correct
and
Going to mess around with it tonight... anything to look out for other than fusible links and the ignition switch?
Old Aug 11, 2016 | 09:44 AM
alloro's Avatar
alloro
It could also be wiring or connectors but I'd start with those two.
