1986 B350 - Cruise + Speedo Problem. Related?
Old Jun 12, 2017 | 08:15 PM
MattGinOK's Avatar
MattGinOK
Default 1986 B350 - Cruise + Speedo Problem. Related?
Hi all. Got a 1986 B350 Class B. Cruise does not work. I changed out servo and it works but not right. Activate cruise at 70 and it immediately bleeds off to about 50. Power for cruise works correctly. Replaced hoses to rule out vacuum leaks (get 10 inches now). Any ideas?
Is the pinion and cruise connected in some way? No
R there no 1986 cruise experts out there?
Edits:
1. Vacuum test = 15 inches.
2. Got to thinking (uhoh). Maybe the speedo pinion at the trans? It has a 32 tooth pinion. I have a 38 tooth pinion. Does the internal gear have to be changed to accommodate the 38 gear pinion? I don't believe it does but never hurts to ask.
3. Speedo pinion corrected w/33 tooth.
Attached Thumbnails 1986 B350 - Cruise + Speedo Problem. Related?-p1060962_cruise_servo.jpg   1986 B350 - Cruise + Speedo Problem. Related?-p1060963_cruise_servo.jpg   1986 B350 - Cruise + Speedo Problem. Related?-p1060965_cruise_servo.jpg
Last edited by MattGinOK; Sep 9, 2017 at 03:53 PM. Reason: Speedo pinion corrected w/33 tooth.
Old Sep 13, 2017 | 03:30 PM
MattGinOK's Avatar
MattGinOK
Default Solved! - Disconnected wire.
Talk about a disconnect! Yikes. Evidently my initial troubleshooting was mistaken. The single wire on the speed control servo goes to the 'actuator' on the front of the carb. I stole a diagram and added just the carb part. On the bright side, I know all there is know (almost) about the speed control on a 1986 Dodge B350 Van Class B.
Attached Thumbnails 1986 B350 - Cruise + Speedo Problem. Related?-quadrajet-rebuild-final-side7.jpg
Old Sep 13, 2017 | 04:56 PM
tjkoko's Avatar
tjkoko
As a gentle recommendation, the next time you list the vacuum, please indicate if it's taken at idle or under load. And in the case of the latter please indicate the speed: highway, up/down hill.
Old Sep 13, 2017 | 07:29 PM
MattGinOK's Avatar
MattGinOK
Default Recommendation taken.
I agree. Just was not thinking thru other situations.
Old Mar 16, 2024 | 09:00 PM
Paul123's Avatar
Paul123
Default Cruise control not working on 1986 b350
I’m trying to get my cruise control working on my 86 b350. Is this the wire that connects the CC Servo to the carburetor,?
Old Mar 17, 2024 | 09:45 AM
That one is for the electric choke I do believe.
