AnLake, thought I'd bump you up and ask if you've had any luck with the guy's suggestions given? Had seen you posted in another thread by slowsneakers of similar problems as yours
I would replace the crank sensor. They can be heat sensitive that's why it doesn't do it until it warms up(30 miles). It will not set a fault code either.
Replaced the crank sensor today in 15 minutes! So far so good will drive more tomorrow to test it out!! Grateful:
So far I have replaced the coil and the crank sensor---no luck so far. I have been trying to find a pcm rebuilt. Located one, had a different #. Mine is a 115AE the one they had is a 115AA. Need to find out if it will work. Next may try a ignition switch.. Seems like a lot have had this prob, no real answers yet
