Ram van 2000 250 5.2liter Very high idle, HELP
Old Dec 1, 2017 | 01:35 PM
greenthumb's Avatar
greenthumb
I am going to have to check i.a.c. to make sure.Thought had 12v.+ 5 but better double check.I don't have one of those weird light deals,I'm a carpenter not a tech, Scotty. Any way appreciate all help!
Old Dec 1, 2017 | 02:59 PM
A cheap test light is all ya need.
Old Dec 1, 2017 | 03:19 PM
greenthumb's Avatar
greenthumb
Used test light + multimeter before thought it all checked out. thanks
Old Dec 1, 2017 | 08:26 PM
Are you getting power on two wires??
Old Dec 2, 2017 | 11:04 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Originally Posted by greenthumb
Yeah what he said about plenum gasket I know can be a problem,but I did check for block blowby and all set there.
If by "block blowby" you're testing the piston rings, then that has nothing to do with a leaking plenum gasket.
Here is a picture of the plenum plate on the bottom of the intake.
Attached Thumbnails Ram van 2000 250 5.2liter Very high idle, HELP-24568238983.jpg
Old Dec 2, 2017 | 02:20 PM
greenthumb's Avatar
greenthumb
May have used wrong term! There was a videos on YouTube how to check.By plugging or pvc chk. Can't remember exactly how but that's bout it.creates a suction at Valve cover or something.Its been a few wks.Memory ain't what it used to be! I believe if plenum gasket leaking it effects your vacume then your idle!
Old Dec 2, 2017 | 02:27 PM
With PCV disabled, you should have a little bit of pressure in the crank case. If you still have vacuum, that's a sure sign the plenum is blown.
Old Dec 2, 2017 | 03:51 PM
greenthumb's Avatar
greenthumb
Thanks going to 2d check that to!
Old Dec 3, 2017 | 10:23 AM
alloro's Avatar
alloro
Right, you disconnect the vacuum hose from the PCV valve, plug the hose and plug the valve. Pullout the dipstick and connect a vacuum gauge to the dipstick tube. Run the engine and the piston ring blowby will build some pressure, but if a vacuum is drawn then the plenum is leaking. This test will not work if you have leaks in the crankcase system anywhere, such as a leaking valve cover gasket, or the grommet the PCV valve sits in, etc..
Old Dec 10, 2017 | 12:21 AM
greenthumb's Avatar
greenthumb
What is the whining you refered to? I have had an alternator whine for a long time but I thought it was caused from diode's going bad.
