van just shuts off
Old Dec 15, 2017 | 01:15 AM
dtcn's Avatar
dtcn
Default van just shuts off
I have a 1991 dodge ram van B250 5.2l engine and when I start my van, it will run for a while and then it will just shut off completely. I used to be able to wait for about 20 seconds before I could start it again, but then it would start doing the same even more frequently until I would have to call a tow truck to get it home. It does not have a crank shaft sensor on the transmission housing bell, and I replaced the alternator because it was not charging the battery. would the eggine control module have anything to do with this, and will I have to replace it ?
Old Dec 15, 2017 | 11:30 AM
Need to find out what's missing when it quits. Are you losing fuel, spark, or both..... Weather permitting, drive with the engine cover off for a while. Next time it quits, check for spark, and see if you are getting fuel.
Old Oct 7, 2018 | 12:28 PM
neilmck's Avatar
neilmck
I see this happened a year ago but it sounds like the Hall Effect Sensor located under the distributor rotor. I had the same issue and a new HES solved it.
Old Oct 8, 2018 | 11:27 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
No but it has a pickup coil in the distributor that does the equivalent job. Start by replacing that, or the other possibility that comes to mind is a bad ignition coil.
