Which Torque Converter?
Old Feb 14, 2018 | 03:26 AM
Poagman's Avatar
Poagman
Default Which Torque Converter?
I have a 1991 Dodge B150 RamVan with 5.2L and OD cut-off switch on dash.
What size and stall speed torque converter should I get?
I put my info in a stores website and it shows different depths and stall speeds. How do I decide?
Old Feb 14, 2018 | 12:21 PM
Stick with stock stall speed. (I think around 1600-1800) Unless you have some performance upgrades, stock is all you need. Buy a GOOD one though, an 80 dollar t/c is NOT a 'good' one.
Why are you replacing the t/c in the first place?
Old Feb 14, 2018 | 05:33 PM
Poagman's Avatar
Poagman
I don't know stock spec.
When I enter make/model into Autozone the "vehicle specific" results returned options with 24 to 31 splines and starting stall speeds ranging from 2400 to 3200.
I can count the splines, but not depth and stall speed.
Old Feb 15, 2018 | 09:45 AM
Which transmission do you have?
Old Feb 15, 2018 | 10:43 AM
Poagman's Avatar
Poagman
The A904/A500. Here is a pic of the ID tag
Old Mar 4, 2018 | 03:25 AM
Poagman's Avatar
Poagman
Default ** Update **
i am told it is the A904 transmission, but when you add the overdrive, the assembly is then an "A500"
