Smelling antifreeze
Old Apr 5, 2018 | 03:01 PM
Ramvanman96's Avatar
Ramvanman96
Question Smelling antifreeze
Seems after running the van then parking it, I smell antifreeze as I walk in front of my van. It's not real strong but noticeable. It has a new radiator three years ago along with a thermostat. The van runs great with no leaking anywhere, over heating or coolant loss in the radiator. How is this possible? Is there something I should look for? It's a '96 with the 5.2, 318.
Old Apr 6, 2018 | 09:34 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Could be a minuscule drip allowing coolant onto the engine where it evaporates.
Old Apr 6, 2018 | 11:13 AM
Or a pinhole leak in a hose.
Old Apr 19, 2018 | 02:30 PM
Ramvanman96
Thanks guys! I'll have to start looking/investigating a little closer to see what I can find..
Old Apr 19, 2018 | 08:17 PM
JFloors's Avatar
JFloors
Mine was same a couple years ago after changing the thermostat and housing, upper hose too. I had clamped the hose tight at both ends knowing it's a hassle to go back and have a leak at the housing but with a few heat cycles it began to have a small leak. I think the pressure buildup loosened it enough to allow coolant to pool up after shut down around the thermostat housing. Take a flashlight and inspect in that area, (I know, not much room to see) to see if that may be where the leak might be...
I had set the clamps so could get to it just pulling the alternator aside. I ended up doing that, re-tightening the clamp and adding another one, same for at the radiator as it had developed just some slight wetness around that connection there.
Old Apr 20, 2018 | 02:31 PM
Ramvanman96
Thumbs up
JFloors, Thank you for explaining and helping out. This weekend I'll pop the hood as well as the inside cover to get a direct look at the engine to see what I can find. It sounds like you may be right as I have no leaks underneath the van. There has to be a small pool/leak on the engine somewhere.. I should have everything replaced as it's pretty old and due. Two years ago my mechanic said everything looked great. Since the thermo, housing and hoses are fairly cheap I should probably go ahead and replace them. Thanks again!
