Blower motor shuts off when switched to “ high “
I hear and feel the clicks though the relay except for the high speed setting on the blower switch. All related fuses are intact. I have replaced resister, the blower speed switch itself and the main hvac ac relay. I bought a new blower motor and hooked up the 2 wire existing harness to it and cycled through the blower switch as well. Still, when I switch to the high speed blower, it just shuts off.😕
the high speed blower relay should only click on when the high speed fan speed is set. it is not used at any other speed so you should not hear any relay clicking in low, medium or medium high. the a.c relay and high speed blower relay are separate relays
the high speed does not run through the resistor...it runs on a separate circuit straight to grd
if you remove the high speed blower relay there will be 4 pins. with the key in run, engine off(koeo) you should have
-2 should have battery voltage red/drak green and light green/white
-2 should have ground black/violet and black/tan
report back on what has power and grd.
grding the light green/white wire pin of the relay should put the fan on high speed.
Ok. It seems I’m having trouble locating the “ high speed “ relay. I see the main hvac relay, the ac clutch relay, the high speed 50 amp fuse and the fuses in the panel on the driver’s side of the dash. Is the relay you are talking about behind the ac control panel in the dash? I’m sorry for sounding like an idiot but I’m learning as I go. I have a Haynes repair manual and I try to find possible similar repairs on video. I am really appreciating the help I get from everyone.
the diagram I have (from all data service information) shows the high blower relay located in the power distribution center, in the engine compartment next to the battery. if the pdc cover doesn't label the relays...try the owners manual
the only relays shown in my hvac diagram are the high blower motor and compressor clutch relay. the diagram does not show a main hvac relay.
If you remove the high blower relay...all other fan speeds should still work.
All this BS I’ve been going through was due to the parts store selling me the wrong relay...I’m no mechanic so I end up taking for granted I’m being sold the right part. Turns out the relay I was sold, was a flasher for a trailer connection. Smdh... end up blowing ac related fuses as well. Long story short, got the right part, everything works. I do appreciate the helpful advise though. Many thx.
