Anyone got electric seats in their van? fuse diagram
Hi guys,
Still having no luck with the electric seats guys.
OK back to basics now, does anyone have electric seats in their dodge van? If so do you know where the fuse is for this? Is it a fuse or a relay? Where is it located?
I have the manual for the standard van and it does not mention electric seats/ none of the fuses say electric seats.
Does anyone have a diagram of the underhood fuses too please? I can't find a diagram of that either.
Please help guys, hard to drive the van as it is currently.
Hello Americanmuscle1989,What year is your van and do know you the conversion company like mine is Regency. In mine there is panel with the fuses for the fold down bench bed and worthless mood lights. Look around behind the driver seat there may be a panel. It may located on drivers side close to the floor.
Thanks for your help buddy, its a 1995 B2500 van with a StarCraft conversion.
I don't suppose you can upload a picture can you?
I have looked around the bottom of the drivers seat and inside the cupboards etc and no luck. To the left of the drivers seat is the seatbelt area but no panel that can be accessed for example.
I should add I have also switches for internal lights and tv and electric bed so there must be another starcraft fuse block somewhere but I just can't find it
The power seat circuit breaker is located at the top on the of the main fuse block on the right had side, The panel behind seat only has a relay and fuses for the rear seat, tv and mood lights.
Reason: grammar
Thanks so much for your help with this, additional question please (bear with me if i'm being dim, I will explain what I see in the van)
Please see the attached pictures, of where the fuse box is located (next to the passenger glove box) and then under the panel that shows the fuses. None of the fuses have tripped and the the relays for the windows and door locks, numbers 16 and 8 both operate their jobs well.
The circuit breaker for seats may be # 16 or 8. Your panel is different from mine. Check your fuse cover see if they list the fuses and circuit breakers. # 16 or 8 may be what you want.
