2” Lift on 1994 B250
Old 08-27-2018, 03:33 PM
JAM84's Avatar
JAM84
JAM84 is offline
Default 2” Lift on 1994 B250
Brand new here, first post. Bought a (new to me) 1994 B250 2WD and I am looking to clear 31” ATs. I saw there are some old threads about this but no specific products are mentioned. Coil spacer would be fine up front, anyone know of one (part number) that would work for 2” lift?
As for the rear: I have a Jeep XJ with shackle relocation brackets, they are great and added 2”. Anyone know if they would also work on the B250?
Old 08-27-2018, 06:35 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,380 Likes on 3,120 Posts
Gotta be careful with ball joint angles up front.
What size are the stock tires, and how much clearance do you have?
Old 08-27-2018, 07:59 PM
JAM84's Avatar
JAM84
JAM84 is offline
Thanks for the reply. 235/75/15 - which are 28” tall.
Front is ok on height, 3”. Full lock is about 1.5” - 2”. Plenty of room in rear, 3-4” or clearance. I would like to do coil spacers and 31”s. What are you thoughts?
Old 08-27-2018, 08:04 PM
Widebody's Avatar
Widebody
Widebody is offline
I have a set I installed from mcBay Performance. Mine is a 2001 ram van 3500 though. Looking at their website the same could spacers I used fits all can models but skips a few years for some reason. Not sure why they wouldn't fit but looks like they are out of stock.
  • 1971-1980 B100 / B200 / B300 Van
  • 1981-1991 B150 / B250 / B350 Van
  • 1995-2003 Ram Van B1500 / B2500 / B3500
  • 1971-1989 D100 Pickup 2WD
  • 1977-1993 D150 Pickup 2WD
  • 1971-1980 D200 / D300 Pickup 2WD
  • 1981-1993 D250 / D350 Pickup 2WD
  • 1994-2008 Ram 1500 2WD
  • 1994-2009 Ram 2500 / 3500 2WD (Independent front suspension ONLY. Solid axles take 4x4 lift)
  • 1975-1993 Ramcharger 2WD
Old 08-29-2018, 03:38 PM
JAM84's Avatar
JAM84
JAM84 is offline
I will check this out. Thanks for the info!
Quick Reply: 2” Lift on 1994 B250
