Trip Computer resets @ Power off
Old Feb 18, 2019 | 12:18 AM
aldouse's Avatar
aldouse
Default Trip Computer resets @ Power off
I searched around the forums already and alas haven't found anything definitive or that solves for me.. so figured I'd ask.
Trip computer resets back to zero every time i power turn off the engine. I have a brand new battery and the radio manages to keep its memory, so why not the trip computer? Odometer works fine. I'd honestly like to use the trip computer for measuring out my mpgs and trip distances between fills.
Old Feb 18, 2019 | 11:04 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Any blown fuses?
Old Feb 19, 2019 | 02:40 PM
aldouse's Avatar
aldouse
alas... no. fuses blown. all of that seems to be working..
is there a wiring diagram that shows where the trip computer pulls from the battery so maybe I can try to work my way back to see if there's a corroded line or something?
Old Feb 19, 2019 | 10:26 PM
What year is your van?
Old Feb 21, 2019 | 04:35 PM
aldouse's Avatar
aldouse
its a '99, b1500. the 5.2L V8
Old Feb 21, 2019 | 06:57 PM
ramvan61's Avatar
ramvan61
This link might help you with the wiring diagram:http://www.bbbind.com/free-tsb
Old Feb 21, 2019 | 07:35 PM
Replace fuse 12 in the junction block. 15a fuse. That is what supplies the cluster power when the ignition is off, for memory. If that doesn't solve it, likely the cluster itself has an issue.
Old Feb 25, 2019 | 05:33 PM
aldouse's Avatar
aldouse
Thanks! Let me give that a try when I get the van back. Currently at the shop to get the heater core, thermostat, and heater control valve replaced.
