Having problems getting it to run
Old May 5, 2019 | 08:00 AM
Alan Patty's Avatar
Alan Patty
Default Having problems getting it to run
Van has set for 2 years starter was bad I replaced it than I got it started for around 2 min then it slung the belt alternator locked up then it wouldn't start back put Altenator on it it started up ran 2 or 3 min turn it off now it won't start back put 10 gal new gas in it,what should I check next. Thanks
Old May 5, 2019 | 08:08 AM
Will it crank, just not fire?
What year van? What engine?
Old May 5, 2019 | 10:32 AM
Alan Patty's Avatar
Alan Patty
Default 2001,318 motor
What should I check first fuel filter,fuel pump,spark ?
Old May 5, 2019 | 10:51 AM
What year is it? Engine?
How much gas was in it before you added some?
Old May 5, 2019 | 10:55 AM
Alan Patty's Avatar
Alan Patty
Default Gas
I'm not sure but it have fuel stableliser in it I put 10 gal in it and now it almost on a half tank the fuel gauge don't work unless it's running
Old May 5, 2019 | 02:14 PM
So, probably not a lot of gas was left in it. (actually, it probably wasn't even really gas any more......)
Still need to know what year, and what engine.
Old May 5, 2019 | 03:22 PM
Alan Patty's Avatar
Alan Patty
Default 2001,318 motor got it started 2 times run 5 min total won't start back what should I
I been looking at utube and I think by the fuel gauge not working and brake lights on and others it's the brain box over the motor,PCM
Old May 5, 2019 | 03:24 PM
Alan Patty's Avatar
Alan Patty
Tried to start it again today,nothing,Any suggestions,Thanks
Old May 5, 2019 | 05:04 PM
Need to check and see if you are getting spark, and see what fuel pressure looks like. Do you hear the fuel pump prime when you first turn the key?
