2000 Ram Van Chariot rearend going out
Old Jun 17, 2019 | 05:04 PM
CTCR's Avatar
CTCR
Default 2000 Ram Van Chariot rearend going out
Wondering what years are interchangable. Also wondering if ANY other make/models could be interchangeable. TiA!
Old Jun 18, 2019 | 09:47 AM
What weight rating?
Old Jun 18, 2019 | 11:50 AM
CTCR's Avatar
CTCR
What weight rating?
Thank you for your reply. The van is a 1500.
Old Jun 19, 2019 | 07:52 AM
Likely the dodge 9.25 rear then. I should think that any van of the same body style and weight rating would be a likely candidate for a donor. Might even be able to take one out of a 2nd gen half ton truck. (although, there might be a difference in width??)
Old Jun 28, 2019 | 01:42 PM
wca_tim's Avatar
wca_tim
Truck rear end is about 4 inches wider than the van and spring perches are in the wrong place...
find one in a u pull it lot. if you get a couple years later, might get lucky and find with disc brakes... ;-)
QUOTE=HeyYou;3442842]Likely the dodge 9.25 rear then. I should think that any van of the same body style and weight rating would be a likely candidate for a donor. Might even be able to take one out of a 2nd gen half ton truck. (although, there might be a difference in width??)[/QUOTE]
Old May 10, 2020 | 11:03 AM
frumpster's Avatar
frumpster
Disk Brakes??? My 1998 B-3500 with the 9.25 rear has drum. What year has disk brakes,ir i wanted to upgrade? Also, haw much work is involved to switch in a dana? Same pinion angle?
Old May 10, 2020 | 11:24 AM
A 3500 with a 9.25???? That doesn't seem quite right.
Old May 10, 2020 | 11:47 AM
frumpster's Avatar
frumpster
Yup. Would have liked a Dana or a Truck rear,but it has the corperate 9.25 with a 3.92 ratio and 3.5 inch brakes. I see a 50/50 mix in the wreckers up here in canada. I run Amsoil 80w140 sever gear.I was thinking the heavier oil would keep things cooler in the mountains. I dont drive it in the winters. Have put about 10,000 miles on ti with the amsoil. seemes to be ok!
