1990 b-250 idle speed actuator
I just cleaned my throttle body, but I had a problem before, where while driving, the idle would go really high. I could usually hit the gas pedal and it would slow down. I just figured out that vacuum hose thing I posted about a few days ago, and took it for a test drive. When I got to the stoplight by my house, the idle cranked up, and would not go down, even after hitting that gas pedal a few times. So, I turned around. It also has a major lack of power now too, but I'll deal with that later. I popped the doghouse and air filters, and started it up again and it was idling normal. I can plainly see the idle actuator moving around. I dont know if its getting stuck, or if the electronics are doing it, or some other reason... Should I grease the actuator piston?
Whenever it does this, its usually after about five minutes of driving. I think it eventually goes away though.
Any ideas?
Any ideas?
Its an old van . There probably is.
Let me ask you this: What vacuum related component could be making the idle actuator do that? maybe I could narrow down a vacuum leak if I knew. My list of possible causes: Bad idle actuator, Bad throttle position sensor, ECM, (god I hope not)
I ordered a few cheaper components from Rockauto, like a Fuel pressure regulator and air temp sensor and a throttle position sensor.
I feel a little overwhelmed trying to find vacuum leaks, to tell you the truth....
Well, I checked out the vacuum lines, and none looked bad, but I replaced all the bigger ones coming from the throttle body. Took a quick test drive, and there is no high idle, so far, so hopefully that was the ticket. I do remember it didnt always kick into high into high idle mode though...
