Steering gear box and rust
Old Jan 30, 2020 | 11:10 AM
Sweetwater6725's Avatar
Sweetwater6725
Default Steering gear box and rust
So I bought a van that has bad rust around the frame and steering box. My main question is has my steering box already detached from the frame (bent) or is it supposed to sit on an angle? The van was cheap enough to buy for parts but is this able to stay on the road?
Old Jan 30, 2020 | 03:18 PM
Have someone move the steering wheel, while you watch the box, if the box appears to be solidly mounted, then it should be ok.
Old Jan 30, 2020 | 03:34 PM
Sweetwater6725
I have wondered this but haven't gotten logistics for the second person yet. Would the tires need to be on the ground to provide the right load or friction?
Old Jan 30, 2020 | 04:43 PM
I think that would be best.
Old Feb 6, 2020 | 08:09 AM
Busted Nuckles's Avatar
Busted Nuckles
That frame section is shot and either needs to be stripped, cut out and new section properly welded in or taken off the road. Umm, my experience tells me this could lead to a fatality.
Old Feb 6, 2020 | 08:17 AM
Sweetwater6725
Yes Ive come to the conclusion that its done being on the road without a lot of welding. There is minimal flex with the wheels off the ground but once it flexes to the point of breaking - thats not worth it.
Old Feb 6, 2020 | 08:37 AM
Busted Nuckles
With that being said, if it were mine I would fix it myself to the point it would be better than factory.
