Tranny Service
Old Apr 8, 2020 | 10:38 PM
Eunospeed's Avatar
Eunospeed
Default Tranny Service
Time for a transmission service. Will replace the filter and fluid in my 02 3.9L w/ the 3 speed auto. Planning to go with Castrol ATF+4 but open minded to other brands. Question; how many quarts will I need to top her off after I pull the pan and replace the filter?
Old Apr 9, 2020 | 08:04 AM
4 to 6 quarts. It varies with how much drips out on you while you are changing the filter. Should adjust the bands while you are in there as well.
Old Apr 9, 2020 | 08:28 AM
Eunospeed's Avatar
Eunospeed
Sounds good. Is there a good thread where I can find instructions on how to adjust the bands? FYI, the van only has 13K miles.
Old Apr 9, 2020 | 09:55 AM
I don't know if there is a thread about it, but, I would be surprised if there wasn't a youtube video about it.
Old Apr 9, 2020 | 11:26 AM
nibroc's Avatar
nibroc
yeah that
Old Apr 11, 2020 | 10:47 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Here is the procedure and the specs. to adjust the two bands.
http://www.dodgeram.org/tech/transmi...T_band_adj.htm
Old Apr 12, 2020 | 10:17 AM
Eunospeed's Avatar
Eunospeed
Excellent!
Old Apr 12, 2020 | 10:29 AM
Eunospeed's Avatar
Eunospeed
Not complex but still scary as I've never done a Transmission band adjustment before. I'll try and video the procedure once I begin the service. Stay tuned!
Old Apr 12, 2020 | 10:48 AM
Eunospeed's Avatar
Eunospeed
https://www.google.com/search?client...LRtAa6jKK4CA28
Found this procedure. Looks pretty easy when watching the video.
Old Apr 25, 2020 | 03:33 PM
Eunospeed's Avatar
Eunospeed
Before the tranny service and band adjustment, can someone tell me exactly what tranny I have? My van is a 2002 1500 with the 3.9 and a three speed tranny. The band adjustments are slightly different between transmissions.
