Checking if I have 2 or 4 wheel ABS
Old Jun 4, 2020 | 09:26 AM
AmericanMuscle1989's Avatar
AmericanMuscle1989
Default Checking if I have 2 or 4 wheel ABS
Hi all,
I need to get 2 new brake rotors so need to check if I have 2 or 4 wheel ABS. 1995 B2500 Conversion van.
I only have 1 sensor wire on the Front Drivers side rotor and not the passenger side rotor, which makes me believe I have 2 wheel ABS.
Can anyone confirm this is correct?
Thanks
Old Jun 4, 2020 | 05:27 PM
There is a wire to the drivers side, but, not to the passenger side???? I didn't think Dodge started pulling that till the third gen trucks..... Odd. In any event, I would be looking where the tone ring was. If it's part of the rotor, then the replacement will also need to have that. If its part of the unit bearing, then I would be wondering why the passenger side isn't there......
Old Jun 5, 2020 | 04:41 AM
AmericanMuscle1989
Hiya,
Does seem odd, ok different route to the answer then.
This is my brake master cylinder, it only has 2 lines coming out, does that mean only 2 wheel abs?
Can anyone confirm please?
Thanks
Old Jun 5, 2020 | 11:20 AM
I see a dump valve there, not the abs controller you would expect on 4wal, so, yeah, you have rear only abs.
Old Jun 5, 2020 | 11:23 AM
AmericanMuscle1989
OK awesome, I was 99% sure but good to check these things!
Thanks very much
