No start, No OBD or CEL 1997 B2500 Van . Tried eveything i know still stumped.
Old Jul 11, 2020 | 12:11 PM
shakeitlikeacaveman's Avatar
shakeitlikeacaveman
Default No start, No OBD or CEL 1997 B2500 Van . Tried eveything i know still stumped.
Stumped trying to get my van going.
1997 dodge 5.2 318 b2500 van
Current Condition:
i have a no start
Engine will crank
i have spark
OBD wont connect
check engine light will not come on.
Work complete:
new fuel pump
crank sensor
ecm
checked ASD/ Fuel Flow relays
Checked related fuses
checked all connectors
evap purge valve
new Variable speed sensor.
notes:
Two weeks ago was driving, stopped at store came back out no start
At that point the obd code was for evap solenoid Code P0443.
I checked evap canister hoses and replaced evap canister purge valve.
(Prior to the no start i had been hearing loud ticking/clicking under hood when driving.)
i was then towed to my house
(It was possible for a short time to hit tank with rubber mallet to engage the pump to start the vehicle.)
it finally left me stranded again.
towed again.
i installed new fuel pump, still no start.
(Prior to the fuel pump procedure and connector check the check engine light was functioning properly.)
Today i replaced ECM, the check engine light came back on. turned the engine over, no start no check engine light
Any help figuring out would be greatly appreciated.
im stumped .
blake
Old Jul 11, 2020 | 12:19 PM
Does the CEL come on when you first turn the key on? If not, check the fuse for the ECM. If you have a spare, just replace it.
Old Jul 11, 2020 | 12:25 PM
shakeitlikeacaveman
No CEL when u turn key.
fuse under hood #17/18 good
fuse in glove box #19 good
Old Jul 11, 2020 | 12:40 PM
Hhhhmmm.... That's odd.
Moving this to the Ram Van section for ya. Hopefully folks there will have more insight.
Old Jul 11, 2020 | 12:57 PM
shakeitlikeacaveman
thanks heyyou .
much appreciated
blake
Old Jul 15, 2020 | 10:05 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Have you tried seeing if it will start using starting fluid? Doing so could confirm or eliminate a fuel delivery issue.
Old Jul 15, 2020 | 11:40 AM
shakeitlikeacaveman
howdy alloro,
no start with fluid.
Old Jul 16, 2020 | 09:15 AM
alloro's Avatar
alloro
Time for a compression test.
Old Jul 20, 2020 | 01:42 AM
BlockHeadGearBender's Avatar
BlockHeadGearBender
Does this model have a distributor? Cam sensor?
Old Jul 20, 2020 | 09:05 AM
Yep, has both. Cam sensor is in the distributor.
