sensor issues
Old Oct 27, 2020 | 09:55 AM
Try the Standard Motor Products sensor. They are *usually* pretty good on quality.
Old Oct 29, 2020 | 10:07 PM
jmondo's Avatar
jmondo
alright i installed the new part, but with mixed results.
sounds like the engine is running quieter and is not having the issue of jerking while in 35-45mph range.
that being said the stalling just after start issue went from infrequent to frequent (1 out of every 4 starts) and the check engine light is on and still says P1391. i cleared the codes and it came back after the next start. thoughts?
Old Oct 30, 2020 | 10:38 AM
Time to check the wiring for the cam and crank sensors.
Old Oct 30, 2020 | 07:40 PM
Busted Nuckles's Avatar
Busted Nuckles
And I would start by inspecting the connectors at the ECM if it's like my 1999.
Old Mar 19, 2021 | 04:07 PM
jmondo's Avatar
jmondo
alright after a long break, I'm back. I ended up having to replace the pick up coil again as the one I first bought actually caused the engine to stall often. I swapped it to another one but I'm once again getting p1391 after I drive for about 50 miles.
I did try to check the wiring last night. there's nothing obvious although the wires are all taped together and I don't feel super confident about going that deep with my inspection. the wires look like they are in good shape on the harness and on the connectors going into ECM.
I called a shop and they told me this same thing, they have to inspect the wires for $125 per hour.
I was wondering...if there's a "computer issue", would you look to the ECM? or TCM? does this van have a replaceable TCM?
and is there anything I should try with my scan tool besides the engine code?
anyone recommend I throw a Hail Mary and just buy a new ECM? looks like I can buy it and plug it in, and if it doesn't work return it and just lose $50. any off the cuff guesses of % chance it's the computer?
looking @ https://www.flashmastersecm.com/prod...ed-to-your-vin
thanks happy friday!
Old Mar 19, 2021 | 06:12 PM
Might be the crank sensor that is causing the issue...... The code is for either cam or crank, intermittent signal.... Since you have been thru a couple cam sensors, might be time for the crank sensor. Unfortunately, the ONLY ones that work worth a darn are the mopar sensors....... which are not cheap. The aftermarket fellers tend to cause more problems than they solve.
Old Mar 19, 2021 | 06:39 PM
jmondo's Avatar
jmondo
ah I should have included that: I've already replaced a mopar crank sensor as well
and the IAC module, distributor cap, rotor, spark plug wires, air filter, pcv and hose
Old Mar 19, 2021 | 08:23 PM
jmondo's Avatar
jmondo
just found an oem cam sensor on ebay so I’ll try swapping that in too. still curious about the other questions if that fails
Old Mar 19, 2021 | 09:56 PM
What year is the van?
Old Mar 19, 2021 | 10:10 PM
jmondo's Avatar
jmondo
year 2000
