Rear and front door gasket seals weatherstrip
Old Oct 19, 2020 | 08:59 PM
ian94b250's Avatar
ian94b250
Default Rear and front door gasket seals weatherstrip
Hi! Hope everyone is well!
I've been trying to isolate why I continue to get exhaust smell in my van. I've improved the situation a bit by patching a rust leak near the exhaust pipe and sealing up window gaskets, but I think the main problem is the rear doors weatherstrip/gasket being cracked and worn.
Does anyone know where I can find replacement weatherstrip for a 1994 B350 van? The front doors also need to weatherstripping, but that can wait.
Thanks for any help!
Old Oct 20, 2020 | 06:03 AM
Busted Nuckles's Avatar
Busted Nuckles
I would start by inspecting the system for leaks. Does your exhaust pipe exit out the side behind the rear tire?
Old Oct 20, 2020 | 12:22 PM
ian94b250's Avatar
ian94b250
I have a new exhaust system with no leaks. Biggest mistake was bypassing catalytic converter... regardless of leaks, the exhaust is so strong smelling I can't really have any windows open. The exhaust exits to the drivers side of the van not the rear unfortunately.
I do need to replace the weatherstrip due to condensation too. Any ideas where I can find weatherstrip that will fit?
Old Oct 20, 2020 | 12:49 PM
LMC Truck? Try here as well.
Old Oct 21, 2020 | 07:04 PM
Busted Nuckles
As a get you by, you may try to get some general stick on weather stripping from Home Depot and put it on the body so the doors seal against it. As I said, a suggested temporary fix.
Old Oct 22, 2020 | 01:08 AM
ian94b250's Avatar
ian94b250
Thanks, that's a good idea! Anything to improve the seal!
Old Oct 22, 2020 | 01:10 AM
ian94b250's Avatar
ian94b250
I have found the front and side doors, not the back. Only the two door style. That is definitely the biggest design flaw on these bad boys. Too heavy on the hinges. I'll keep looking! Thanks!
ian94b250's Avatar
ian94b250
​​​​​​​Thanks! They have some nice stuff there!
